Finally back home from the holidays and back at it again. I found a lovely package from ACS in the mailbox when I got home containing almost every bolt,nut, and washer combo I needed in order to finish up this firewall before the SS goes on. I mounted up the ECU, EIS, and both ignition coils then added a bed of flox and glass over all the bolt/screw heads. These bolts/screws serve as hardpoints for the hardware being mounted so that I just slide the hardware onto the bolts and add a washer and nut. These are also things that will hardly EVER have to be removed after final install. Now all of these will cure and tomorrow I will be moving on to the strake/wing intersections. :)
