By now I feel like my firewall is riddled with bolts, hardpoints, holes and nut plates and it IS! But today I installed the final 2 bolts that will hold the air/oil separator onto the firewall. I drilled into the firewall enough to recess the bolt heads and fill the voids with flox. I then added 1 ply glass over the bolt heads. I also noticed that the 4 bolts holding the engine ECU in place were installed too close to the EIS making it impossible to remove the EIS, so I had to pound out these bolts and install nut plates instead. No big deal, just a little work.
