Shaped the F-696 brackets a little closer to the required final components.
Bit of bandsaw work, followed by sanding disc, and finally the buffing wheel. The 3/4" angle will be fit later - length is determined by position, which will be defined when the wings are inserted.
(Yes, I 'could' rough them out a little closer now but it is just being trimmed to length between two non-parallel angles. Don't need to trim them too much now.)
