Starting at the subpanel in the fwd section, I drilled and deburred the bulkheads along the pilot (left) side of the fuselage. Inserted the grommets, and passed the static tubing through each gromment.
The static tube path is just below the armrest, and inside the baggage compartment side covers.
I stopped for now - just aft of the baggage compartment bulkhead. Will need to locate, drill, and insert the tubing on the right and left sides of the fuselage. Appears that I may have all the hoses/tubing and fittings.
