Get pic and describe bending on the brake and form blocks.
Continued from prev 8/3/06 - on F-642R & L
Preferrably the floor skin is secured with plenty of 'edge clecoes' and properly trimmed and aligned with the fixed references before attempting any of the other steps. In addition, the first 'back-drilled' hole should be in the center of the first rib chosen and work back and forth to each side of that c ... THIS WAS CUT OFF by limitation in KitLog ... lost text.
