Having enlarged the FW to accomodate the conical eng mount (changed alignment of hole), so the normal plug from Vans was too small. Fabricated a steel oversized disk, and a thicker disk for alignment. Used Hi-Temp RTV to seal the hole.
Other panel wiring issues. Fabricated a shorter SV-NET cable to re-arrange the connections behind panel.
