Details of various details; 1) removed the sensor manifold and replaced the bolt/nut with nutplates to facilitate maintenance, 2) replaced 2 bolts on the Master Relay because the grip was short (due to thickness of the mounting bracket), and 3) torque checked all the relay connections.
Also adjusted the left flap pin - resulting in a minor puncture wound from the sharp end of a stainless steel rod - ouch.
