Finished the remaining screws in the rollbar/rear window, and ready to move forward on removing it to re-paint the rollbar, and bolt/rivet the brackets, skins, windows and rollbar permanently in the plane.
(After that the all aft component maintenance becomes more difficult and time consuming.)
Also finished the turtledeck skin mods where it attachs to the rollbar brackets. (Reason for mod - to accomodate the change in screw hole alignment when the rollbar was re-fabricated.)
May also re-visit the left side edge of the rear window plexiglas because it is slightly different than the right side. The gap between the canopy aft edge and rear window is tighter on the left side.
