Two main tasks - Temporary extension of rudder control tube, added 5/8" of tubing with an internal 'plug' to support the assembly until a proper 4130 repair is made. Spoke with a machinist to spec the material and make it. (Just need support of the rubber pedals for a few days.)
Due to a discussion on VAF re: ADAHRS negative influence from steel cables of the seat harness being magnetized. Recommendation to 'fix the movement' to avoid interference.
