Started by riveting the side skins on the canopy frame, and some quick metal polish to clean-up. Opens and closes much better and a little stiffer. A few rivets left to do on the canopy lift angles.
Reviewed the RV-12 wiring diagrams today for a better understanding of the documentation steps, and similarities to diagram for my RV-6A with SkyView and VP-100. With all the Dynon components the basics are so similar on lights, GPS, AP servos, etc., there are benefits to derive. Found a number of wiring simplifications that I could implement (local grounds on the servos, and combining all the power and disconnect circuits on one power pin on the VP-100). This cleans up the wiring in the conduit, remove excess wire, and consolidates the power connections. So I worked through that process but didn't finish. Tomorrow will finalize.
