Mounted HS/VS and rudder to check rudder fairing. Sanded excess resin from rudder fairing. Filed and sanded fairing, attached. Layed up a small muliple layer fiberglass sandwih to apply to fairing surface for tail light/strobe.
Checked wiring route and movement of wires to rudder.
Removed alum HS bottom fairing and cleaned-up edges, then re-installed.
