Got the very expensive ignition wire grommets for the baffle. Only get one chance to do it right so practiced on a hole template. Needs to have a center hole large enough to pass the plug end of the wire. Rear baffle has two good locations.
Layed up in/out layers of resin saturated fiberglass tape on the modified rudder fairing. Fit is much better.
Fixed the nutplates in the 2nd wingtip, for the light covers.
Ordered connectors and supplies for next week (wiring).
