RV-6A - GBC
Date:  5-16-2013
Number of Hours:  1.50
Brief Description:  Subpanel - canopy ejection
Removed the sumpanel and finished the mount on the backside of the subpanel for the canopy ejection handle. Don't plan to have an 'ejectable canopy' but to facilitate the use of the mechansim to release the pins for canopy removal on the ground for maintenance.
Not the bolts are too short on the mechanism, and need to be replaced with the proper length. The UHM block also needs trimming to allow compleate clearance for the bottom of the bolts/nuts when the handle is turned.
Several more hours required to complete these tasks.
Riveted the canopy ejection mount on subpanel
Adjustments needed for clearance
