Decided to do a lot of clean-up chores, including rear window, rollbar review, and top skin rivet planning. Reviewed prerequisites and steps to get these items on the TODO list. Then added a new task; build a storage box for 'stuff' to travel. (All the stuff that you might need in the plane for trips, but should stay in the plane.)
Designed and fabricated a box approx 6x12x16 that will attach to the floor behind the pilot backrest, secured with a hinge.Constructed with .025 AL alclad and .063 AL angle 6061.
Time consuming and only roughed out today.
Also epoxied in the inlet duct airflow components into the top cowl. Pictures later.
