Continued to fit the brace attach brackets, and prepare the rollbar replacement components.
One of the challenges of replacement components is to match-drill all the holes, some of which were easier to drill through the 1st time, in two layers. than to perfectly match a hole which is already final-drilled to size. (1st time with #40 bit).
Lots of disassemble and checking fit along the way. Marking, trimming, deburring, and re-assembly to re-check alignment fit.
