Brief Description: Re-routing of manual trim cable
Cleaned up new faux spar, remove control components, and then examnied the manual trim cable route through the F-604 bulkhead and web of the wing spar. The factory hole for the cable is located close to the inboard end of the left wing spar, and about the spar straps. The most likely place to drill another routing hole will be above the bottom spar 4th large bolt hole.
The area of the web above the 3rd hole is riveted with a spacer/reinforcement, so it's not likely a good place to drill through. I'll send an email to Tech Support for advise.
UPDATE === see 12.16.10 === Abandoned these alternative routing options and found a way to follow original plans.
