RV-6A - GBC
Date: 12-7-2010
Number of Hours: 2.00
Manual Reference: N/A
Brief Description: Remove control sticks & linkage
In order to work on anything significant, it is easier to remove all the control sticks, linkage, and brackets on the aft side of F-604 bulkhead. This allows the best access to the close tolerance bolt holes in the aft side of the 'spar attach' area, necessary to insert bolts or attach nuts. The four steel connecting straps are match-drilled from the factory, and each is marked with the position that it should be installed (example, Top Aft 3119 --- 3119 is the chasis #.)
Very important that these four steel plates are not lost or damaged, as they were match drilled for THIS fuselage center section (spar #3119) and this wing spar.
With the control components completely removed, the access to the area is fantastic, and I'll be able to work on the trim cable routing, electrical wiring and fasteners.
Empty of control components
