Chris's RV-14A Site
Date:  9-23-2017
Number of Hours:  8.00
Brief Description:  Left wing tip
Finished the right wing tip lens. It takes quite a while to get this part done. Sand and fit and sand and fit...... Moved to the left wing tip, riveted the nutplates and wing tip rib in place after trimming approximately 1/4" from the back edge of the tip to match it to the aileron. Opened up both right and left tips to fit the Flyleds circuit boards. Left seam has a layer of spot putty to help fill some pin holes. Should be able to get the tips primered tomorrow after fitting the left lens.
Left tip nut plates
Left tip nut plates
Filling seam
Filling seam
Left tip rib riveted into place
