Working on right wing tip still but close to finished. Riveted the nutplates for the attach screws and riveted the tip rib in the back of the wing tip. All straight forward and finally got to use my nutplate jig on all of the nutplates. It's a huge help and well worth having it on hand. The right wing also has the Archer Nav antenna which is held on with the attach nutplates which also provides the necessary ground to the airframe. The end of the antenna was attached securely to the tip with some strips of fiberglass to hold it in place and prevent and vibration against the fiberglass tip. Started fitting the light lens and it's close, maybe another 30 minutes will have it ready to attach.
