Wired up the FlyLeds position / strobe light boards. The boards need sloght trimming and then interconnect wires connecting the 2 boards together and finally running the 4 wires to the connector in the wing end root. Per instructions, you can test the boards with a 9V battery and even at 9V the lights are very bright and should be realy bright at 14V with the alternator powering the system. I really hate the Molex connectors and will likely change them ohange them out for something else. Even with good crimps I can't seem to get them the pins to all sit properly inside the connector housings.
