Brief Description: Drill control horns for pushrod
Short session after Thanksgiving to final drill the control horns for the pushrod. Drill one side location per plans then install spacer block and drill through to opposire horn. Came out nice and straight. You can see the laser light on the trailing edges to make sure they were in alignment with each other when the bolt and spacer are installed.
