Brief Description: Match drilling the control horns for the center be
Drill hole in the control horn to match the center bearing then match drill in the other horn. The elevators need to be clameped into "trail" or neutral position prior to getting this part done. Then you prepare a spacer block for the pushrod connecting bolt to be sure this hole is drilled perfectly straight through the horns.
