Removed the foam ribs and mixed up a batch of micro. I then used the micro to make fillets on the interior side of the newly cured BID layup. Once that dries, I will add a 2-ply layup to finsih the close out of the aft side of the HS fairing.
Exterior layup has cured - adding micro to the inside
