Brief Description: Fitting and glassing in the foam ribs
Trimmed and glued in the temp foam ribs for the HS fairings. I used hot glue to speed things up and covered the foam with clear packing tape trimmed to the edge of the foam. I then glassed over the foam with 1 layup of BID.
