Brief Description: Initial fitting of HS/Elevator fairings
Moved on to the HS/Elevator fairings. Match drilled the elevator farings to the elevators. Then match drilled the HS fairing to the HS and trimmed the aft edges to have the proper gap and contour between/with the elevator fairings. Compared to the VS and rudder, these fit like gloves and won't need any additonal shaping.
