Brief Description: Final drilled seat belt anchors, cover plates
Received my 6 and 12 inch #12 dril bits the other day so I was able to finsh up final drilling the bar support angle end holes to #12. I was then able to remove the top skins which gave me access to the longerons in order to match drill the seat belt attach anchors. I finshed up by final drilling the 2 rear cover plates to the side skins with a #28 bit.
