Brief Description: Disassembled the tailcone, began deburring
Started today by trimming off the right triangle. I then tore the whole tailcone down, cleaned up the shop and put my work table back up. I then jumped ahead and took care of one more step and final drilled the hole in the aft bottom skin for the tie-down eyebolt to pass through. I then entered deburring hell and began hole and edge deburring everything that has still needed it--which is just about everything.
