Well I picked up where I left off, needing to rebend the left longeron. Before I removed it last night I marked the direction I needed to bend. I basically repeated the same process to make the original bend. But what I thought would be a quick fix ended up being an iterative process of making a bend and then placing it back in the tailcone to check the alignment. After a couple of trys I got it close enough to call it good. I reinstalled it and then clamped it and the right one down in preparation for drilling.
