Brief Description: Attached longerons, spacer, and aft deck
Started the evening by inserting the longerons and qickly discovered I needed to file both slots in the F-1008 frame and the right side slot in the F-1007 frame in order to get the longerons to fit Once that was done, I re-inserted the longerons, taped in the spacer and clecoed the aft deck and doubler into place. I then clamped the longerons, skins, and aft deck IAW with the plans. The right side is good enough, but the left longeron needs to be tweaked a bit to get the apex and the skins even like they're supposed to be. I pulled the left longeron out and will re-bend it during my next session.
Initial fit of longerons
Spacer taped into place (circles are dust, not holes)
