- Made the Tie Down Bar per the plans except I need to tap the end yet. - Assembled and match drilled Tie Down Bar and Rear Bulkhead. - Made the Rudder Cable Angle from the AA6 -063 3/4x3/4 material. Then I made it again after I goofed up the countersink depth. Again, unfamilar and a new countersink cage. - Made Bulkhead Stiffener from J-channel, - Deburred Rudder Cable Angle and Bulkhead Stiffener.
