SCOTT'S WEB SITE
601 XLB Zodiac
Drill, tap threads for AN4 bolt into nose bearing
Safe tie of tapped AN4 bolt
Showing bolts into nylon nose bearing
Bolts and double safety wire
601 XLB Zodiac Home
1334
Brakes/Brake Lines
Control Stick
Engine & Taxi Tests
Firewall
Flight Test
Hangar
Inspection Day
Instruments
Panel
Throttle Setup
Upgrade
Wiring
