Brief Description: Re-riveted nut plates, Fuel system pressure test
Ran the screws into the nutplates and removed one of the pop rivets on all nut plates. Replaced with3-3 solid rivets on both IP and Firewall flanges.
Pulled the airplane out on the driveway and tested the fuel system by droping a short hose into a fuel can and turned on the pumps. No leaks anywhere, the carb filled and the accelerator pump works.
Screwed the top panel back on and deciding how to piece it together by the canopy hinge.
