Brief Description: Finish up forward side skin rivet lines 1 of 3
Marked forward hole at firewall held skin in place with strap and pilot drilled only that one hole. Released strap and ran a straight edge from the forward hole to the rear hole and marked the layout of the lower forward rivet line.
Clecoed the front one and clamped a 3/4" angle offset from the layout line and progressivly, from the center, added one cleco at a time.
