Ron Lendon's Aircraft Mfg.
Date:  11-27-2009
Number of Hours:  1.00
Manual Reference:  WW Distributor
Brief Description:  Fine tuning distributor bushings
Ordered MR Gasket 928G for the springs and bushings to set the advance.
Made template to determine where to notch the rotor plate. Want to talk to WW before cutting metal here.
Called Ron Milan to get rotational information about the distributor, (CW looking in from top). Gonna run it in on the lathe and Ron suggested using the steady rest to hold the body, (good idea!). Got it running at 1500 rpm and no heat, gonna leave it run for 3 hours.
