Ron Lendon's Aircraft Mfg.
Date:  1-7-2012
Number of Hours:  1.00
Brief Description:  Engine idle test
Today the prop was attached and an Idle test was done. Tach works, Engine idles at 750 rpm smoothly now. One of the EGT probes might be bad.
Set timing at 8 degrees at 750 rpm.
Need more fuel to run full static test.
