Brief Description: Make tie rod for Right Aileron 2 of 2
Insert threaded rod in to the rod end at the aileron and back it out a couple of turns. Mark the bellcrank end a little longer than the sight hole. Cut and dress end. Trial fit and check with the clamp removed and the shim still in the flap gap.
Position Aileron Stop and cleco.
Remove aileron and flap, replace and cleco rear bottom skin.
Cleco flap back in position and drill out holes to #21 in the hinge at the rear spar.
