Brief Description: Flip wing and rivet LE ribs on the bottom
Cleaned up the mess then flipped the wing over.
Started riveting at the LE middle and stopped and placed 5/32 clecoes in every hole along the spar. Finished riveting the ribs then removed all the spar clecoes.
I will be removing the bottom rear skin to finish up the wiring and plumbing, not much on this wing, then rivet the bottom skin and get to work on the wing tip.
