Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Fitting fuel tank 4 of 4
Cut red line hole for clearance around filler. Closed wing and clecoed. Tightened filler neck and think I might need a little more filler under one area.
Clearance hole
Closeed and tight
Slight low sopt
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
