Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Fitting fuel filler flange 3 of 8
The hole in the skin is smaller than the notch in the flange but bigger than the treads.
Close the leading edge and cleco in place.
Test fit to see where the tank flange needs to be lower.
Test fit
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
