Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6-WLO-1
Wing Locker Framing
Opened bend in 6-WLO-1-2 Locker Rear Panel to 98 degrees.
Removed the rivets from ribs 5 & 4 around the wing locker cutout.
Cut and Joggled L angle for the upper support of the Locker Rear Panel.
Cut 3 DZUZ strips.
Remove these rivets
Joggle press
Results of Joggle press
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
