Brief Description: Attach leading edge skin to right wing 2 of 3
The 8 rivets are spaced 40mm and the first rivet is 31mm from the edge of the rear bottom skin.
Put Leading edge skin back on the wing under the rear bottom skin and transfered most of the holes except for the spar tip.
At the spar tip I just marked a few holes, but didn't go through the leading edge skin. I drilled them through the leading edge skin only after dissassembling so the spar tip holes would line up when I drilled the rest.
