Started in the morning and spiral wrapped the wing tip end, then wrapped bundle to the wing root. I start by cutting the spiral wrap to length, getting a couple wraps on the bundle then small tywrap it near the wing rib, Make the tywrap tight when it is located, then wrap the bundle to the other end and finish with another smal tywrap.
Image 3) Pitot and AOA routing. Spent some time thinking about this one, had a false start and made some brakets to thread the tubes through. Then looked up a few web sites and came up with this. Run holes through the ribs just like the wires, clamp where appropriate.
