Brief Description: Begin plumbing and electrical in L Wing
Made first wires up for the Landing/Taxi light ground. Used a longer bolt and have them grounded to the same bolt on the other side of the Aeroflas ground.
I checked the resistance between the spar tip and the spar and it is zero, good conductor.
Image 2) Might need to think up another way of securing the wires so the lights can be removed easily and the wires won't chafe.
Image 3) Simple enough, I removed the wire ties and just twisted the wires. They will un twist when removing the lights and I should be able to twist them back when installing the light.
