Brief Description: Getting left wing ready for closure
Pasted up the fittings with EZ TURN (FUELLUBE), quick-drain & finger screen and tightened them in the tank.
Image 2) Test fit the sending unit and looked inside tank to set the placement of the float. Marked flange placement so I can put it back in that position.
Checked ohm readings, set it so empty is 70 ohms, full gives 12 ohms.
