Designing the bubble for the wing tip. First set the template in flight or standing position and strike the verticle line. I did this by setting the template up at the spar angle then striking the line square from there. The point is set rearward 150mm from the spar.
Image 2) Layout the base of the light and make another template.
Image 3) Template fit to the base. Now I will set it in place and figure what the shapes will be flowing into this surface.
