Misinterpeted the Print revisions "35mm from spar rivet line to aft of hole." to mean the edge of the large hole and ended up drilling a screw hole right above the spar. They meant 35mm to the aft screw hole. Anyway it was the first hole I made so I moved everything forward an have a drain hole now. I tried to cover it with a large washer but that won't work.
