Brief Description: Flipped wing over and removed Flap
Flipped the wing over and removed the flap that I had riveted when riveting the Bottom Rear Skin. This piece needs to be loose for wing fitting. Took one of the A5 rivets and ground the stem flat. Used that and the small ball peen hammer to punch out the center of the set rivets. Drilled the heads off and used a drift to punch out the rest of the rivets. Did about 6 first then added Clecos, then did the rest. They all came out just fine.
