Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6W9
Trim line for the wing tip
The tools to transfer the line are known as a Mouse (image 1) and a Surface Gage (image 2).
The Mouse is a precision ground flat bar with a long tapered point. It is used to scratch a line from a solid surface to the sheet metal.
The Surface gage is very adjustable, here we adjust the point of the scriber to the surface.
Mouse (scriber)
Surface Gage
Use bluing on the sheet metal
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
