Brief Description: Cut and fit Aileron control rod 2 of 3
Set the rod ends on the aileron and Bellcrank. Put both in neutral position and measured to the 1/16" sight holes in the rods. Ended up cutting the threaded rod 210mm long. and it worked out OK.
Image 3) Adjusted rod till the belcrank was parallel to the rib.
