Brief Description: Cut and fit DZUS strips for wing locker
Removed the clecoes around the wing locker hole and cut in the radiused corners first. Using the ProSnips made 3 passes cutting to the line. Re attached the door and filed the opening using a vixen and a small fine half round to remove the material a little at a time. Basically split the line and everything fit together.
Image 2) Notched the corners of the dzsus strips to clear the hinge and to fill a gap.
